Forum >Problems using Huskylens with OLED display
userHead geraldchan 2023-04-11 01:22:23 1174 Views1 Replies
I'm trying to use both the Huskylens and OLED together. But it just doesnt seem to be able to work.
I want to display my outputs on the OLED instead of serial.print
icon OLED_display_HuskyLens.zip 1KB Download(0)
2023-06-02 21:46:46
Pls use this library. https://wiki.dfrobot.com/Gravity__I2C_OLED-2864_Display
It is recommended to use the sample program. The library used in your code is not supported by the Gravity I2C OLED-2864 display.
userHeadPic jenna
