Forum >Sen0219 PWM C02 sensor Code doesn't get past beginning...
TroubleshootingGravity
userHead Niko.Sanchez 2023-04-13 12:39:22 791 Views2 Replies
HI all I am using the PWM v2.0 version of this board.
When uploading the code the serial monitor doesn't get past the beginning…
https://wiki.dfrobot.com/Gravity__Infrared_CO2_Sensor_For_Arduino_SKU__SEN0219#target_5
I am using the code from the wiki which states its for the PWM version.
however it never initializes on the serial monitor past beginning.
any help?
2023-06-02 08:07:59
If you are seeing an error message, please share it. Also verify that the baud rate set in your Arduino code matches the baud rate set in the Serial Monitor. The default baud rate is usually 9600, but check the code and make sure it matches the Serial Monitor settings.
2023-06-02 00:44:30
Hello, what board are you using? Could you pls upload your error message?
userHeadPic jenna
