Forum >Arduino not seeing ESP32
userHead james.Clarke 2023-04-14 01:29:36 1993 Views5 Replies
Hi There
I've recently bought a DFRobot FireBeetle (DFR0654) and I struggling to get it to show up in the serial ports with in Arduino
I have tried adding the correct board via boards manager and have added ‘https://download.dfrobot.top/FireBeetle/package_DFRobot_index.json’ to the Additional boards manager URLs but it errors with the following error
Some indexes could not be updated. Get "https://download.dfrobot.top/FireBeetle/package_DFRobot_index.json": x509: “*.dfrobot.com.cn” certificate name does not match input: https://download.dfrobot.top/FireBeetle/package_DFRobot_index.json
Does any one know what I need to fix this ? also is the not having the correct board info the reason the board isn't showing up in the port window or is this something different
Any help would be greatly appreciated
Cheers
James
2023-04-20 23:15:04
Need to download the driver from here https://www.wch.cn/downloads/CH34XSER_MAC_ZIP.html
Issue discussion threadhttps://github.com/LilyGO/LILYGO-T-OI/issues/3#issuecomment-648293224
userHeadPic jeremyhxx
2023-04-20 22:41:26
http://download.dfrobot.top/FireBeetle/package_DFRobot_index.json
HTTP works for me, but my Mac still can't see the device even after installing it.
2023-04-15 07:08:10
Here is a thread about the installation process of this board. You can get a clue from here:
https://forum.arduino.cc/t/how-to-dfrobot-firebeetle-2-esp32-e-dfr0654-installation-advice/1094480
james.Clarke wrote:
Thanks for getting back me I have been through tips but nothing seem to help,
Thing I am getting rather than anyone else is that the board just isn't showing in up ports of Arduino.
Should just be a simple as plug the board in and the board should show up in the serial ports or am I missing a step ?
Cheers
James
2023-04-15 14:25:44
2023-04-14 02:44:49
Sorry I should of added I've tested on 2 x Macs, 1 Mac mini running os12.4 and MacBook Pro M1 also running 12.4, I have tested other esp32 on the same machine and they show up fine
userHeadPic james.Clarke
