Forum >current to voltage converter v1.0
General Gravity
userHead gusornelas 2023-04-14 10:08:40 1718 Views4 Replies
Hi everyone I hope you can help me with this, I would like to know what diodo TVS model have the module current to voltage converter v1.0.
Thanks in advance for your help.
2025-04-15 04:31:38
It looks like it would be a problem if I grounded the power supply as shown above…
Since there is no ‘isolation’ on the converter module.
It also seems like it could be a problem if it is left floating like the datasheet shows…
Wouldn't it be better to swap the sensor and the converter in the circuit so that both the power supply and the arduino can use the same ground reference?
userHeadPic FRED.STEELE
2023-12-18 08:12:26
what are resistors R2 and R5? Diodes D1, D2 and D3 are the same?
Thank you
userHeadPic zanivanov
2023-07-11 09:15:24
Hi!
I have the same board an trying to get a stable voltage value with an input current range of 4mA-20mA. I'm using an LM2596 to get a more stable voltage to feed the SEN0262, but I'm unable to get a stable voltage value at all.
Any clue to where look to get usable values?
Thanks in advance,
Jordi
userHeadPic Jordi.Gras
2023-06-02 00:38:30
Sorry for the late reply.
D3:   24V TVS zener diode
Hope that helps.
userHeadPic jenna
