Forum >SEN0496 Gravity - Oxygen Sensor and Raspberry Pi pico W
Raspberry PiGeneral
userHead Andrea.Cosola 2023-04-14 23:49:56 1157 Views3 Replies
did you know if is compatible with RPi Pico W and microphyton?
Any libraries/sample code?
If not compatible there is an alternative for Pico?
Thanx in advance,
Andrea from Italy
2023-04-16 21:15:47
Micropython library connection of this product:
https://github.com/DFRobot/DFRobot_EOxygenSensor/tree/master/python/raspberrypi
userHeadPic Xiao
2023-04-16 21:14:33
此产品的micropython库连接:https://github.com/DFRobot/DFRobot_EOxygenSensor/tree/master/python/raspberrypi
userHeadPic Xiao
2023-04-15 07:17:24
Could not find any micropython library for gravity oxygen sensor. Grove - Gas O₂ Sensor(MIX8410) however is compatible with Raspberry Pi 4. I think you can modify the sample code for pico.
