Forum >Query about Analog TDS sensor
Troubleshooting
userHead GODSON 2023-04-23 06:27:16 957 Views1 Replies
I brought a TDS sensor today. Do I need to calibrate everytime when I use it. Also after uploading the sample code from Dfrobot, I got 0ppm as the value from sensor. Is there any problem with sensor and after calibrating it will it be ok
2023-05-11 02:55:11
The TDS sensor will store the calibration parameter in the EEPROM of your main board.
So you don't have to re-calibrate the sensor every time you use it.
But if you use the sensor on another board, you have to calibrate the sensor again.
userHeadPic Yeez_B
