Forum >Intelligent Rain Detection Module
userHead Emre.Çakmak 2023-05-02 11:25:55 2138 Views7 Replies
Anyone using the module? Anyone know how to use it? Can you help me? How to update the module? The module does not respond to me even though I have made the connections correctly?
2024-09-07 03:01:06
I have just bought this module,
If you manage to make it work, Can you confirm  the wiring given on https://www.dfrobot.com/product-2611.html:
Wiring:Black-VCC,White-UART_RX,Yellow-UART_TX,Red-GND
I't not a typing error for Black-VCC and Red-GND ?
it is not a standard use
thank you in advance for your help
userHeadPic Vesta.Domos
Yeez_B wrote:
The right wire order for this module is:
2023-05-19 19:04:59
2024-09-07 03:00:33
It's recommend you to use any of the Serial Debugger to debug the sensor first, before you actual connect it on your MCU board.
Serial Debugger:
https://www.dfrobot.com/product-2291.html
And you could debug the sensor by the software like putty or SSCOM.
SSCOM:
https://www.acusys.co.kr/?p=779&ckattempt=1
And send the data as: 3A 00 00 00 4B in HEX to see if the module gives you the feed back.
userHeadPic Yeez_B
2023-08-02 01:19:37
This module seems perfect for making auto-wipers in a car project, but the datasheet says it should not be stored in direct sunlight for extended periods. That seems contradictory?
userHeadPic Dirk.Meintjies
2023-05-23 07:51:48
Thanks for Wiring image.
I'll be able to test more soon
2023-05-20 23:33:56
I was wondering if I could make an automatic plant watering system like this:
https://www.pcbway.com/project/shareproject/Smart_Plant_Watering_System_1b11fa7d.html
using the intelligent rain detection module. I think it will be more user-friendly if there is an Arduino sample code.
2023-05-03 01:08:24
Have you studied the datsheet and user manual?
