Forum >SKU:DRI0039 Quad Driver not reversing motors
ArduinoTroubleshooting
userHead eddyg 2023-05-02 17:14:44 567 Views1 Replies
I am using this board and I cannot get the motor to reverse or go forward using your code from wiki.
I am using pin 3 for an encoder, but I am using motor 3 so this should not be an issue I would think.  Any ideas?
2023-05-09 19:40:30
It is recommended that you use pin8 to control the motor direction.
If you post the code, we will help you solve the problem faster.
userHeadPic jenna
