Forum >from 6-55 V dc dc to 24 V converter
userHead delyiman 2023-05-17 11:01:19 469 Views2 Replies
Hello! I need to make a 24V source to bring energy in my PCB. I choose the MP4560 but I don't know how to create the final circuit. Do you help me with that?
2023-05-18 00:54:37
What is the purpose of your circuit. The MP4560 is basically a step down converter. What is your desired output? You can refer to the application circuits given in its datasheet. Here is also an example. The circuit can generate 3.3V output from 4.5V to 55V input range:
https://www.monolithicpower.com/en/mp4560.html
2023-05-17 20:14:05
Which MP4560 module do you use? Could you pls upload the image of the MP4560 module?
please refer: https://www.monolithicpower.com/en/mp4560.html
Hope that help!
userHeadPic jenna
