Forum >GP8302 20mA I2c on Pi 4 fail
userHead John.Doe6403 2023-05-17 12:00:06 1484 Views4 Replies
I am currently struggling to get the demo for the GP8302 0-20mA current regulator running.
I work with the raspberry pi python code  https://github.com/DFRobot/DFRobot_GP8302/tree/master/python/raspberrypi
I connected the wires as follows to the raspi pins
black 4 → GND
red 2 → 5V
blue 5 → SCL
green 3  → SCA
The Pi has i2C enabled.
I keep getting Error code 2  (2: Device not found, please check if the device is connected)
Has anyone successfully controlled the chip with the pi?
Does it require to have the 18-24V connected to respond on i2c?
thank you for your help
2023-05-20 10:54:53
Thank you for your responses. I can confirm that after also providing the 24V, the module now communicates and works.
userHeadPic John.Doe6403
2023-05-18 00:35:09
Check if your power supply is providing the necessary voltage and current. Still if it makes problem, kindly check the GP8302 20mA with any other board.
2023-05-17 17:48:29
After our confirmation, you need to power the VIN port with 18-24V to enable the module.
userHeadPic Yeez_B
