Forum >Maqueen Wall Following MAZE
General 3D Printing
userHead james.Maitland 2023-05-25 16:12:43 3074 Views2 Replies
After some trialing and modifications I have 3d printed. a holder for the maqueen to allow a 90 deg mounting of the ultra sonic an 2 touch sensors.
I will update with access to videos, 3d files for printing and the iterations of code
#wall runner using side facing ultrasonic and push button
ideal_follow = 4
#assumes 4cm is a good distance to follow wall
distance = ideal_follow
#sets the initial distance to the ideal_follow distance
wall_range = 1
#sets the amount the robot can be away from the wall
waitonce = 0
#used to pause the robot for 5 seconds to position it correctly
def on_forever():
global distance
global waitonce
global ideal_follow
global wall_range
#accessess the global variables in all functions
if waitonce == 0:
basic.show_icon(IconNames.SQUARE)
basic.pause(3000)
waitonce = 1 #resets so id does not pause again
# get a new reading
distance = maqueen.ultrasonic(PingUnit.CENTIMETERS)
if distance > ideal_follow and distance < ideal_follow + wall_range: #the ideal range
maqueen.motor_run(maqueen.Motors.ALL, maqueen.Dir.CW, 50)
basic.show_arrow(ArrowNames.NORTH)
elif distance < ideal_follow: #getting too close to the side wall
maqueen.motor_run(maqueen.Motors.M1, maqueen.Dir.CW, 50) # slow turn left
maqueen.motor_run(maqueen.Motors.M2, maqueen.Dir.CW, 25)
basic.show_icon(IconNames.SAD)
elif distance > 10:
maqueen.motor_run(maqueen.Motors.M1, maqueen.Dir.CCW, 15) # fast right left no wall left
maqueen.motor_run(maqueen.Motors.M2, maqueen.Dir.CW, 45)
basic.pause(65) #change this to the time it take to turn 90 deg #opening in wall 90 deg left turn
else: #getting too far from the side wall
maqueen.motor_run(maqueen.Motors.M1, maqueen.Dir.CW, 25) # slow right left
maqueen.motor_run(maqueen.Motors.M2, maqueen.Dir.CW, 50)
basic.show_icon(IconNames.HAPPY)
if input.pin_is_pressed(TouchPin.P1): #hit the wall at the front
maqueen.motor_run(maqueen.Motors.ALL, maqueen.Dir.CCW, 75) # fast reverse
basic.pause(200)
maqueen.motor_run(maqueen.Motors.M1, maqueen.Dir.CW, 45) # fast right left
maqueen.motor_run(maqueen.Motors.M2, maqueen.Dir.CCW, 15)
basic.show_arrow(ArrowNames.NORTH_EAST)
basic. Forever(on_forever)
2023-05-26 18:47:37
Here is the photo But How do I load the Student activity and STL files
userHeadPic james.Maitland
2023-05-26 18:45:57
Here is the final prototype of the Ultrasonic holder. It now has extra clearance for the LED's on the right and 1.5mm pilot holes for the microswitch screws. And some lugs for doing cable management
