Forum >Internal Pull-Up on DFR0575 (Beetle ESP32)
userHead rohandharwadker 2023-05-26 06:50:44 733 Views1 Replies
I can't seem to get a simple switch working using the internal pull-up resistor on the DFR0575 Beetle ESP32. The following code always outputs HIGH whether the button is pressed or not:
`void setup() {
Serial.begin(9600);
pinMode(4,INPUT_PULLUP);
Serial.println(digitalRead(4));
delay(500);
2023-05-26 19:43:14
We've done pin mapping for the Beetle-ESP32. In your code, you need to write D4. For example:
pinMode(D4,INPUT_PULLUP);
or
Serial.println(digitalRead(D4));
userHeadPic jenna
