Forum >SEN0524 - Cant download NAssistant 64bit
Troubleshooting
userHead daniel.hags 2023-06-10 07:01:24 637 Views5 Replies
I'm trying to change the protocol of the SEN0524 ToF sensor to i2c. Following the wiki I need to download NAssistant software, but I only receive a .crdownload file when downloading the 64bit version. When testing the 32 bit version I can start the program but it crashes when I press the recognize icon.
2023-06-12 08:10:28
Thanks for the reply.
Disabling the firewall didn't help. Looking at the download link it seems to be a .crdownload file (https://dfimg.dfrobot.com/nobody/wiki/9d3ae205bc323a916241ad1ce41039ba.crdownload) unlike the 32bit version (https://dfimg.dfrobot.com/nobody/wiki/e829eee8c280ca89cb03c9b6701db2f4.zip) which is a .zip
Running as an adminstrator didn't help either. But I suspect the issue is running the 32bit version on an 64bit machine.
userHeadPic daniel.hags
jenna wrote:
Sorry for the inconvenience. We have updated the download file.
2023-06-12 23:41:20
jenna wrote: 2023-06-12 23:42:22 daniel.hags wrote:
Thanks jenna, now everything works
2023-06-13 09:53:13
2023-06-11 03:39:19
Temporarily disable any antivirus or firewall software that might be interfering with the download or execution of the NAssistant software. Remember to re-enable them after completing the installation.
Run as administrator: Right-click on the NAssistant executable file and select "Run as administrator" to ensure that the software has the necessary privileges to make changes to your system.
