Forum >Capacitive Fingerprint Communication Failed Error
Troubleshooting
userHead nine7 2023-06-13 06:29:57 725 Views4 Replies
I have this Capacitive Fingerprint Scanner/Sensor Arduino - DFRobot  fingerprint scanner and i cant seem to change the baud rate back, The defualt read was 57600 when i ran the code, it changed to 8389400 and now it has a communication failure error and i can get anything to work on the fingerprint scanner.
What can i do to restore this to work.
2023-06-13 18:16:04
Pls modify the code. The module initialization baud rate needs to correspond to the baud rate in the code.
FPSerial.begin(57600);
userHeadPic jenna
2023-06-13 17:24:10
Could you attach the screenshot of the code and the screenshot of your serial monitor?
I found the "communication failed" occured only when you not wired properly or power it under wrong voltage.
userHeadPic Yeez_B
2023-06-13 10:42:28
Is the fingerprint.setBaudrate(fingerprint.e115200bps); function not working?
nine7 wrote:
i ran the code and its now saying communication error
2023-06-13 11:36:38
