Forum >Firebeetle 2 -e RDB led comes on and cant work out why.
userHead Gary.Bradshaw 2023-06-14 01:56:57 360 Views3 Replies
I have a Firebeetle 2 -e connected to 1307 RTC and Micro sdcard.
RDB led comes on when sdcard is plugged in and CS pin set on SD card to D7
Any ideas?
2023-06-14 17:39:57
Could you pls upload the code? IO5/D8 is the pin of the RGB light.
You can try adding this code.
userHeadPic jenna
2023-06-14 17:25:36
The on-board LED is connected to the D9 pin.
Sure you are not do anything to the D9?
userHeadPic Yeez_B
2023-06-14 15:01:32
Hello, which product exactly? This one? https://www.dfrobot.com/product-2676.html
