Forum >One firmware causes bootloop on Huskylens
userHead chris.slater 2023-06-14 06:16:45 1002 Views3 Replies
Using a mac
if I load HUSKYLENSV0.4.7bStable.bin on the Husky ( i have 10 units, 2 work 8 don't) it boots and then reboots continuously.
if I load HUSKYLENSV0.4.9Class.bin it works fine.
All loaded on the same machine on with the same terminal commands over the same USB cable.
2023-06-16 04:32:05
HUSKYLENSV0.4.7bStable.bin causes continuous rebooting while HUSKYLENSV0.4.9Class.bin works fine. It suggests that there might be compatibility or stability issues with the specific firmware version.
2023-06-14 18:09:45
It is recommended that you upgrade to the latest version of the firmware to get the latest features and the most stable experience. The firmware version required by the wiki is not lower than V0.5.1a. This version integrates all functions together.
userHeadPic jenna
2023-06-14 11:46:43
Tried it on a Ubuntu machine and it still boot-loops
userHeadPic chris.slater
