Forum >Help for Urm14 use
Help for Urm14 use
userHead Dieudonné.SAMA 2023-06-28 18:18:47 827 Views1 Replies
I have bought an Urm14 and the rs485 shield, but not able to make them work properly.
Can anyone help me 🙏🙏🙏
2023-06-28 22:04:41
What board are you using?
productImage
When uploading the code, the switch on the shield must be turned OFF, otherwise the upload will fail. After the upload is completed, turn it ON to allow the shield to work normally.
wiring diagram:
userHeadPic jenna
