Forum >Detecting Zones with mmWaveRadar SEN0395
Troubleshooting
userHead jetdillo 2023-06-28 18:46:35 914 Views3 Replies
I notice that there are Library functions to set the distance in different zones on the SEN0395. How do we read the data in those zones ?
Is there a way to tell what distance a person is at ?
2023-06-28 21:54:31
SEN0395 can only output high and low levels, and cannot read the distance.
Maybe you will be interested in this product: SEN0557
userHeadPic jenna
jetdillo wrote:
What function do the different zone settings have then ? This function lets you set the distance in different zones on the sensor:  detRangeCfg (par1 parA_s parA_e parB_s parB_e parC_s parC_e parD_s parD_e)
If I use that, how can I read the data in the different zones ?
What's the purpose of that if you can't read the data after you set it ?
2023-06-29 12:43:34
jenna wrote:
This command can set the detection distance range of the sensor. If there is a person in the detection range, the sensor will output 1.
2023-06-29 17:48:47
