Forum >LattePanda Sigma wifi card aerial(s) cable(s)
General LattePanda
userHead Fustercluck 2023-07-04 17:07:28 1066 Views2 Replies
I can see the aerial terminals on the wifi board. I have the aerial cables….. so I connect them to the terminals, and run them where?? The far end(s) of the cable(s) have a sticky pad on them…. so where are they meant to be fitted. Any particular route for the wires? I can't find any info……. thanks
2023-07-05 02:28:00
Hello Peter,
When I use it I usually leave the pads lying around, the antenna works fine that way, it is not high gained, just like the ones used in laptops.
Best Regards,
userHeadPic xingzhao.zhu
2023-07-04 22:06:58
You could connect the Antennas onto the wireless network module.
If there is a sticky pad at the end of your antenna, you can fix the antenna in any place with good WiFi signal
userHeadPic Yeez_B
