Forum >Gravity pH Meter V2.0
TroubleshootingGravity
userHead Tino 2023-07-06 07:32:45 877 Views2 Replies
I just bought pH Meter V2.0, and uploaded the code as described on the dedicated page.
The point is that I read "ph=nan" on the serial monitor, despite good wiring.
The probe is working, since I have some values returned while using another generic code.
So it seems the issue is linked with the library.
Any idea about this please?
Kind regards.
2023-07-10 01:51:40
Thank you.
That helped!
userHeadPic Tino
2023-07-06 19:48:08
Hi!
pls check the FAQ:https://www.dfrobot.com/forum/topic/315131
userHeadPic jenna
