Forum >Gravity Speech Synthesis V2 - What is AOP and AON?
GravityTroubleshooting
userHead David.Lichtenstein 2023-07-13 09:45:13 909 Views3 Replies
I'd like to know what the AOP and AON connections on the circuit board are. I connected them to a scope and it looks like digital output (when a voice is playing through the speaker). If this is so, are there specs available such that I can make use of this digital output?
If not, is there an analog output so I can connect the output to a better amplifier and speaker?
Thanks for anyone's help!
2023-07-14 17:26:30
Oh, is there a way to disconnect the built in speaker when I use the audio output, or should I just de-solder it?
userHeadPic David.Lichtenstein
2023-07-14 17:23:58
Thanks!
2023-07-13 21:55:29
These two pins can be connected to the power amplifier (D) and external speaker.
userHeadPic jenna
