Forum > Help me
HUSKYLENSGeneral
Help me
userHead Bard17 2023-07-25 00:28:31 1237 Views6 Replies
I am doing a smart recycle bin project with huskylens in which it segregate into different bins. My problem comes when I tried to include reward system by using April tag. It always not functioning as intended. What should I do?
2023-09-25 00:12:02
@Bard17: Is it possible to change from object classification to tag recognition then get back to object classification?
Yes, you can switch algorithms back and forth programmatically. Just allow enough time for the camera to adjust to the new settings.
userHeadPic tguneysu
2023-07-25 07:18:33
What problem are you facing? Aren't your system recognizing the tags?
2023-07-25 12:10:12
2023-07-25 03:24:02
I have sent an email to tech support with hex file. Please check
userHeadPic Bard17
2023-07-25 02:30:09
Hi!
Please describe in detail the difficulty you encountered. Thanks for more details.
It is recommended that you use the tags provided by the wiki.
wiki:https://wiki.dfrobot.com/HUSKYLENS_V1.0_SKU_SEN0305_SEN0336
userHeadPic jenna
Bard17 wrote:
https://drive.google.com/file/d/11OP03I4gHWT35G4GSK8-gpdtKgC3bx62/view?usp=drivesdk
2023-07-25 03:40:11
