Forum >DFR0913 12v - 3.3v Level Shifter
I have a photo sensor that outputs PNP at 12v @25mA and say I connect it to the 12v side of DFR0913… can this switch the 3.3v side ( level) high?
2023-08-23 17:44:06
Yeez_B
Sure you could.
On the left side for the above picture, you could connect “Signal Input” to you 12V positive of your sensor.
And the "Signal GND" to your 12V negative.
