Forum >For DC motor FIT0487, exactly which JST connectors?
How to select
userHead Kevin.Wible 2023-08-26 10:25:01 558 Views2 Replies
For the DFRobot FIT0487 DC motor, the datasheet says it comes with “2-pin 1.5 mm JST connector x1”, and “4-pin 1.5 mm JST connector x1”.
It looks to me like JST makes 3 different lines of 1.5mm pitch connector families.  How do I figure out the exact part number of the connectors provided, so that I can select the mating parts?
Kevin
2023-08-29 06:52:17
Thank you!
userHeadPic Kevin.Wible
2023-08-28 17:30:05
It's ZH 1.5.
userHeadPic Yeez_B
