Forum >pin connector
pin connector
userHead Edward.Douglass 2023-09-18 12:54:41 871 Views2 Replies
Looking for description or recommendation for female connector to fit 3-pin male output pins on DFR0559 board.
2023-09-20 06:29:24
It's 2.54mm male pin so you could use the ordinary Dupond wire to hook it up.
userHeadPic Yeez_B
2023-09-19 01:31:09
Hello Edward,
This F/F jumper cable should work with the pins on the board:
https://www.dfrobot.com/search-jumper.html
or this F/M jumper cable:
https://www.dfrobot.com/product-467.html
In most cases, any typical breadboard wire that fits can be used.
Cheers,
userHeadPic xingzhao.zhu
