Forum >Capacitive Fingerprint Scanner with ESP32
userHead Ninad.Deshmukh 2023-09-18 21:57:12 485 Views3 Replies
I need help to interface the fingerprint scanner with the ESP32. When I tried to do it and run an example from “DFRobot_ID809.h” library (fingerprint registration) , it showed “communication with device failed, please check connection”.
2023-09-20 20:46:46
Ensure proper wiring and connections. Double-check baud rates and power supply.
userHeadPic Alan.Scott
2023-09-20 07:19:28
Share the circuit diagram or connection chart. Also, check if your jumper wires are all OK.
userHeadPic lia.ifat
2023-09-20 06:21:39
Could you please share us with a photo of your wire connection? That will help us to check if you had missed something.
userHeadPic Yeez_B
