Forum >Need Help with Fingerprint Scanner Interface on ESP32
userHead Alan.Scott 2023-09-20 20:49:28 829 Views2 Replies
Hi everyone,
I hope you're doing well. I'm currently working on a project where I need to interface a fingerprint scanner with an ESP32 microcontroller. I'm encountering an issue when trying to run an example from the "DFRobot_ID809.h" library, specifically for fingerprint registration. The error message I'm getting is "communication with device failed, please check connection."
Here are some details about my setup:
- As per the documentation, I have successfully connected the fingerprint scanner to the ESP32 using wiring.
- I have successfully configured the baud rates.
- The power supply appears to be reliable.
I'm not sure what's causing this communication error. Has anyone else encountered a similar problem, or can you provide some guidance on how to troubleshoot and resolve this issue?
Any help or advice would be greatly appreciated. Thanks in advance!
2023-09-26 01:19:16
Please follow the steps mentioned by Yeez_B. Also, check your jumper wires.
userHeadPic lia.ifat
2023-09-23 01:06:16
1- Could you upload the I2C scanner code to see if the sensor is well connect on your ESP32?
I2C scanner for ESP32:
https://www.esp32.com/viewtopic.php?t=4742
2- The sensor only tested under the FireBeetle ESP32, would you be able to use it on the FireBeetle ESP32?
https://www.dfrobot.com/product-1590.html
userHeadPic Yeez_B
