Forum >LoRa Cover on ESP32
LoRa Cover on ESP32
userHead KenMullins 2023-10-03 14:17:54 899 Views1 Replies
I have a firebeetle LoRa cover on a firebeetle ESP32 and I'm trying to connect to TTN via LMIC. I came across a post that explained the LMIC pins required however when I jumped the pins and uploaded the examples under MCCI LoRaWAN LMIC library, both ttn-otaa and ttn-adp, the board boot cycled. The issue is with D5 to DIO1, when this is unplugged it doesn't boot cycle but it also doesn't connect to TTN.
has anyone been successful in attaching a firebeetle LoRa cover with firebeetle ESP32 to TTN?
Pin Mapping For LMIC
const lmic_pinmap lmic_pins = {
.nss = 27, //D4 MUST jumper from CS
.rxtx = LMIC_UNUSED_PIN,
.rst = 25, //D2 MUST jumper from RST
.dio = {26, 9, LMIC_UNUSED_PIN}, //D3 Jumper to DIO0, D5 Jumper to DIO1
Boot Cycle Output
rst:0x3 (SW_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
mode:DIO, clock div:1
load:0x3fff0030,len:1412
load:0x40078000,len:13400
load:0x40080400,len:3672
entry 0x400805f8
ets Jun  8 2016 00:22:57
2023-10-03 14:30:43
Sorry the link to the original pin mapping post didn't come out. It's https://www.thethingsnetwork.org/forum/t/dfrobot-firebeetle-lora-cover-ttn/21089/8
userHeadPic KenMullins
