Forum >Infrared Laser Distance Sensor (50m/80m) SEN0366
Troubleshooting
userHead krunal.dekivadiya 2023-10-08 01:22:20 910 Views0 Replies
hi, Recently procured the SEN0366 (distance sensor)
it was working fine out of the box, i was trying to reduce the MeaInterval time with following command
first i set it to 1 second as shown in manual by changing this Time interval(1S): FA 04 05 01 FC
i can set it to 5 second as well but now the issue is not able to reduce less then 1 second i.e. what mentioned in manual about sample rate 0.05 to 1 second
i need to use this in continues mode only with following command : 80 06 03 77
plz help, or is there any way to reset to factory data
regards
krunal D
