Forum >DFRobot display is not working?
TroubleshootingArduino
userHead Casey.Connor 2023-10-21 18:34:09 2347 Views2 Replies
Hello – I have a “Fermion” DFRobot 420x320 display and I can't make it work.
I am connecting to an ESP32 DevKitC-VIE (pinout here).
I have done:
VCC→5V pin on ESP32
GND→GND
SCLK→18/"VSPI_SCK"
MOSI→23/"VSPI_MOSI"
MISO→19/"VSPI_MISO"
CS→5/"VSPI_SS"
RES→16/"GPIO16"
DC→17/"GPIO17"
BLK→not connected
SCL→22/"GPIO22"/"WIRE_SCL" (not using touch screen yet)
SDA→21/"GPIO21"/"WIRE_SDA" (not using touch screen yet)
INT→not connected (not using touch screen yet)
Example code:
#include <Arduino.h>
#include "DFRobot_GDL.h" //must add "SD" and "FS" in lib_deps
#define TFT_DC 17
#define TFT_CS 5
#define TFT_RST 16
DFRobot_ILI9488_320x480_HW_SPI screen(/*dc=*/TFT_DC,/*cs=*/TFT_CS,/*rst=*/TFT_RST);
Serial.begin(115200);
while (!Serial) delay(10);
Serial.println("reset");
Serial.println("fill screen");
screen.fillScreen(COLOR_RGB565_RED);
Serial.println("done");
delay(1000);
Terminal output is as expected:
fill screen
done
fill screen
done
…but the screen never turns red.
Any help? Thanks very much!
2023-10-22 05:49:31
Hi, I suggest you test the display in an Arduino UNO with the given code in the wiki.
https://wiki.dfrobot.com/3.5inches_480_320_TFT_LCD_Capacitive_Touchscreen_SKU_DFR0669
userHeadPic lia.ifat
2023-10-21 18:44:20
Second link is not working for some reason; pinout is here: https://docs.espressif.com/projects/esp-idf/en/latest/esp32/_images/esp32-devkitC-v4-pinout.png
userHeadPic Casey.Connor
