Forum >DFPlayer Mini. file name vs file index
userHead Nikhil.S Kumar 2023-11-23 06:07:45 1264 Views0 Replies
i have copied 5 mp3 files in sd card and it have names 001.mp3 to 005.mp3. and played it in the order 1-5.
0x7e, 0xff, 0x06, 0x03, 0x00, 0x00, 0x01, 0xfe, 0xf7, 0xef
i used the above command to play first file, but instead it played 5th file.
0x7e, 0xff, 0x06, 0x03, 0x00, 0x00, 0x02, 0xfe, 0xf6, 0xef
similarly instead of 002.mp3 it played 004.mp3.
Then i reversed the playing order, that is 5→1. but when i used the following command, that is for playing 005.mp3, it played 001.mp3.
during copying if i copied in the descending order that is 5→1, the first file positioned will be 005.mp3. and when passing command for playing 001.mp3, it might treated the 1 as file index instead of file name. Is this true?. file index is valid and file name is irrelevant?.
icon DF_player_2.X.rar 8KB Download(0)
