Forum >Gravity: Analog pH Sensor / Meter Pro Kit For Arduino / temperature compensation
userHead Account cancelled 2017-12-20 13:59:30 2145 Views1 Replies
Does this pH-Sensor has an internal temperature compensation?
Because the pH-Level depends on the watertemperature.
Or do I have to measure the temperature with an external device and do a conversion with the Arduino?
2017-12-20 22:43:56 Because we didn't put any temperature compensation function in the sensor, neither hardware nor code. we recommend to use the sensor under 25 Celsius environment. userHeadPic robert.chen
