Forum >Maqueen Lite Not Working with the Gamepad
userHead mechpilot1976 2024-02-03 19:22:05 703 Views1 Replies
I'm trying to get my Maqueen Lite with the forklift to be able to be controlled using the DFRobot gamepads.
I used this tutorial from DFRobot educational forum. https://edu.dfrobot.com/makelog-308487.html
The sample code I'm trying to use is as follows https://makecode.microbit.org/_CkVduYFjHhjX
This code used to work for me in the past, but now it says “The hex file is not available, please connect to the internet” even though I'm clearly connected to the internet.  (See the screenshot below)
I'm not sure what's wrong, but if anyone has working code to use the gamepad with any of the mechanic components or any insights, I'd greatly appreciate it.
2024-02-07 01:27:58
This looks like an outdated extension causing the error.
Would you please switch to JavaScript and click on Explorer, then click on the refresh button next to maqueen and compile and upload the code again.
userHeadPic Yeez_B
