Forum >URM07 (SEN0153): Setting the adress
userHead David.Martinez 2024-02-09 03:39:52 335 Views0 Replies
I am trying to change the adress of these sensors with the next code. After using it, the blue LED in the sensor has not worked again. I would like to know if the sensor is broken or if I can fix it and how.
// # Pin VCC (URM07 V1.0) -> D3     (Arduino Leonardo)
// # Pin GND (URM07 V1.0) -> D2     (Arduino Leonardo)
// # Pin  RX (URM07 V1.0) -> TX1/D1 (Arduino Leonardo)
// # Pin  TX (URM07 V1.0) -> RX1/D0 (Arduino Leonardo)
#define header_H    0x55 //Header
#define header_L    0xAA //Header
#define device_Addr 0xAB //Address
#define data_Length 0x01 //Data length
#define set_adress_CMD 0x55 //Command: Set adress
#define set_adress  0x05 //Command: Change adress
#define checksum    (header_H+header_L+device_Addr+data_Length+set_adress_CMD+set_adress) //Checksum
unsigned char i=0;
unsigned char Adress=0;
unsigned char Operation_confirmed=0;
unsigned char Rx_DATA[8];
unsigned char CMD[7]={
  header_H,header_L,device_Addr,data_Length,set_adress_CMD,set_adress,checksum}; //Distance command package
  pinMode(2, OUTPUT);
  pinMode(3, OUTPUT);
  digitalWrite(3, HIGH);  //Ultrasonic VCC
  digitalWrite(2, LOW);   //Ultrasonic GND
  Serial1.begin(19200);  //Serial1: Ultrasonic Sensor Communication Serial Port, Buadrate: 19200
  Serial.begin(19200);   //Serial: USB Serial Data output, baudrate: 19200
  for(i=0;i<7;i++){
    Serial1.write(CMD[i]);
  delay(150);  //Wait for the result
  i=0;
  while (Serial1.available()){  //Read the return data (Note: this demo is only for the reference, no data verification)
    Rx_DATA[i++]=(Serial1.read());
  Adress=(Rx_DATA[2]);
  Operation_confirmed=(Rx_DATA[5]);
  if (Operation_confirmed == 0xCC){
    Serial.println("Operation completed");
  else{
    Serial.println("Operation Failed");
  delay(1000);
  Serial.println(Adress);
If you are not sure of its usage, there is a document in which all the data is explained.
Thanks!!
