Forum >Stability of the 5V output of DRI0042 driver
userHead smartrmax 2024-03-07 07:15:01 493 Views1 Replies
Hello everyone,
I saw in the Wiki that the DRI0042 motor driver can supply 5V output for Arduino, and my questions is the following : if the motor is at maximum power, will the driver still give 500 mA max if the arduino needs it ? Like, will it distribute the current in a smart way instead of giving everything to the motor, wich could make the arduino unstable ?
Thank you in advance,
Maxence.
2024-03-08 23:17:37
The 5V output still delivers 500mA when the motor is operating at maximum current.
These two circuits are separate.
userHeadPic Yeez_B
