Forum >W5200 starting nothing happening
Troubleshooting
userHead Bing.GGo 2024-03-24 12:37:11 390 Views0 Replies
Hello,dfrobot
just got the W5200 shield
and connected to arduino UNO
the board and shield connected and connected to ethernet cable going to router with DHCP
Version of IDE 2.3.2 Arduino IDE
Following the W5200 documentation
https://wiki.dfrobot.com/Ethernet_Shield_for_Arduino_W5200_SKU_DFR0272
simply nothing happens
the sketch been uploaded to arduino UNO, the board is fine when uploading other sketches to it, so no issue should be with the board
I also can't ping the device using the ip address in the sketch
what should I start looking into to fix this.
thank you
Using the example in ethernet library Webserver
