Forum >Ethernet Shield V3.0 with Arduino Uno Can't configure DHCP
userHead Bing.GGo 2024-03-24 13:36:27 397 Views0 Replies
Using the sample code from dfrobot (see below)
Arduino IDE2.3.2
Ethernet shield V3.0 (https://wiki.dfrobot.com/DFRduino_Ethernet_W5100S_SKU_DFR0125#target_6)
getting can't configure DHCP and then shield was not found
the shield is connected correctly
the board is checked it works
the ethernet cable is fine, its a home network through a router d-link with DHCP ability
all my otherdevices such as laptops, raspberry pi, esp32 have no issue getting dynamic up addresses from router
code sample
Udp NTP Client
Get the time from a Network Time Protocol (NTP) time server
Demonstrates use of UDP sendPacket and ReceivePacket
For more on NTP time servers and the messages needed to communicate with them,
see http://en.wikipedia.org/wiki/Network_Time_Protocol
created 4 Sep 2010
by Michael Margolis
modified 9 Apr 2012
by Tom Igoe
modified 02 Sept 2015
by Arturo Guadalupi
This code is in the public domain.
#include <SPI.h>
#include <Ethernet.h>
#include <EthernetUdp.h>
// Enter a MAC address for your controller below.
// Newer Ethernet shields have a MAC address printed on a sticker on the shield
byte mac[] = {0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED};
unsigned int localPort = 8888;       // local port to listen for UDP packets
const char timeServer[] = "time.nist.gov"; // time.nist.gov NTP server
const int NTP_PACKET_SIZE = 48; // NTP time stamp is in the first 48 bytes of the message
byte packetBuffer[NTP_PACKET_SIZE]; //buffer to hold incoming and outgoing packets
// A UDP instance to let us send and receive packets over UDP
EthernetUDP Udp;
 // You can use Ethernet.init(pin) to configure the CS pin
 //Ethernet.init(10);  // Most Arduino shields
 //Ethernet.init(5);   // MKR ETH shield
 //Ethernet.init(0);   // Teensy 2.0
 //Ethernet.init(20);  // Teensy++ 2.0
 //Ethernet.init(15);  // ESP8266 with Adafruit Featherwing Ethernet
 //Ethernet.init(33);  // ESP32 with Adafruit Featherwing Ethernet
 // Open serial communications and wait for port to open:
 Serial.begin(9600);
 while (!Serial); // wait for serial port to connect. Needed for native USB port only
 // start Ethernet and UDP
 if (Ethernet.begin(mac) == 0) {
   Serial.println("Failed to configure Ethernet using DHCP");
   // Check for Ethernet hardware present
   if (Ethernet.hardwareStatus() == EthernetNoHardware) {
     Serial.println("Ethernet shield was not found.  Sorry, can't run without hardware. :(");
   } else if (Ethernet.linkStatus() == LinkOFF) {
     Serial.println("Ethernet cable is not connected.");
   // no point in carrying on, so do nothing forevermore:
   while (true) {
     delay(1);
 Udp.begin(localPort);
 sendNTPpacket(timeServer); // send an NTP packet to a time server
 // wait to see if a reply is available
 delay(1000);
 if (Udp.parsePacket()) {
   // We've received a packet, read the data from it
   Udp.read(packetBuffer, NTP_PACKET_SIZE); // read the packet into the buffer
   // the timestamp starts at byte 40 of the received packet and is four bytes,
   // or two words, long. First, extract the two words:
   unsigned long highWord = word(packetBuffer[40], packetBuffer[41]);
   unsigned long lowWord = word(packetBuffer[42], packetBuffer[43]);
   // combine the four bytes (two words) into a long integer
   // this is NTP time (seconds since Jan 1 1900):
   unsigned long secsSince1900 = highWord << 16 | lowWord;
   Serial.print("Seconds since Jan 1 1900 = ");
   Serial.println(secsSince1900);
   // now convert NTP time into everyday time:
   Serial.print("Unix time = ");
   // Unix time starts on Jan 1 1970. In seconds, that's 2208988800:
   const unsigned long seventyYears = 2208988800UL;
   // Subtract 70 years and change to China time zone:
   unsigned long epoch = secsSince1900 - seventyYears + 28800;
   // print Unix time:
   Serial.println(epoch);
   // print the hour, minute and second:
   Serial.print("The UTC time is ");       // UTC is the time at Greenwich Meridian (GMT)
   Serial.print((epoch  % 86400L) / 3600); // print the hour (86400 equals secs per day)
   Serial.print(':');
   if (((epoch % 3600) / 60) < 10) {
     // In the first 10 minutes of each hour, we'll want a leading '0'
     Serial.print('0');
   Serial.print((epoch  % 3600) / 60); // print the minute (3600 equals secs per minute)
   Serial.print(':');
   if ((epoch % 60) < 10) {
     // In the first 10 seconds of each minute, we'll want a leading '0'
     Serial.print('0');
   Serial.println(epoch % 60); // print the second
 // wait ten seconds before asking for the time again
 delay(10000);
 Ethernet.maintain();
// send an NTP request to the time server at the given address
void sendNTPpacket(const char * address) {
 // set all bytes in the buffer to 0
 memset(packetBuffer, 0, NTP_PACKET_SIZE);
 // Initialize values needed to form NTP request
 // (see URL above for details on the packets)
 packetBuffer[0] = 0b11100011;   // LI, Version, Mode
 packetBuffer[1] = 0;     // Stratum, or type of clock
 packetBuffer[2] = 6;     // Polling Interval
 packetBuffer[3] = 0xEC;  // Peer Clock Precision
 // 8 bytes of zero for Root Delay & Root Dispersion
 packetBuffer[12]  = 49;
 packetBuffer[13]  = 0x4E;
 packetBuffer[14]  = 49;
 packetBuffer[15]  = 52;
 // all NTP fields have been given values, now
 // you can send a packet requesting a timestamp:
 Udp.beginPacket(address, 123); // NTP requests are to port 123
 Udp.write(packetBuffer, NTP_PACKET_SIZE);
 Udp.endPacket();
