Forum >Pressure sensor triggers vibration - How to build?
How to selectGravity
userHead Darryl.Schick 2024-03-30 16:33:39 869 Views0 Replies
Hi, I am a EE but have never used these products before and hoping for a little guidance.  I want to connect a pressure sensor (like this - https://www.dfrobot.com/product-1844.html) to a vibration module (like this - https://www.dfrobot.com/product-1542.html) so that if pressure is exerted on the sensor, the module vibrates.  It needs to be battery operated.  What other components would I need (type of battery, interconnect wiring, microprocessor, etc.) and can you give me a basic idea of the interconnections and programming that would needed (if cpu/programming is required)?  Thank you!
