Forum >Gamepad example code gives hex file not found
userHead Pieter.van Horssen 2024-03-30 02:22:34 286 Views3 Replies
I want to use the code in https://makecode.microbit.org/_YdWVgV7j7LhA
to connect to the Gamepad but receive Hex file not found when downloding to the maqueen lite using makecode.
2024-03-30 09:16:48
It appears that the gamepad example code is encountering an issue where the hex file it needs cannot be found. This could be due to a file path error, missing files, or incorrect file references in the code. Double-checking the file paths and ensuring all necessary files are present should resolve this issue. https://fmapps.org/
userHeadPic beiroot.max
beiroot.max wrote:
<a href="https://fmapps.org/">Fm Whatsapp</a>
2024-03-30 09:17:38
Pieter.van Horssen wrote:
What has this to do with a ** program.
2024-03-30 09:30:28
