Forum >Measuring salt heigth in tank with water. Measure through water or detect water above salt.
How to selectArduino
userHead Tim.Meeus 2024-04-19 06:53:47 839 Views3 Replies
I'm looking for solutions for measuring the salt heigth in a tank filled with water and salt (softener tank).
Water level can be higher or lower than salt level. Are there any non-contact sensors that can differentiate between water and salt?
Or distance sensors that measure the salt through the water?
All help is welcome.
2024-04-21 10:17:28
how about install this sensor near the bottom of the tank.   It should read DRY when the water level falls below the sensor.
https://www.dfrobot.com/product-1470.html
userHeadPic dalepa
Tim.Meeus wrote:
Thanks for the suggestion. I would like to avoid drilling holes in the tank and not sure the product would survive the conditions in the salt/water tank, which is extremy corrosive.
I was thinking about using a huskylens. Could it destinguish water being above the salt level?
2024-04-23 01:52:59
Yeez_B wrote:
Huskylens don't differentiate between the salinity of the water, and the AI camera isn't powerful enough to get this done.
2024-04-25 23:31:16
