Forum >LattePanda Mu & 7" eDP Display ?
userHead Rick.Downs 2024-04-21 07:24:09 503 Views1 Replies
Is the older 7" display(Alpha/Delta)  compatible with the new Mu.  If so, how is it connected because the 7" display uses a 30-pin flex cable, but there's no eDP 30-pin connector on either the Mu CM module, or the Lite breakout board.  If not, will I need a newer 7" eDP display?
Rick
2024-04-21 08:01:27
^ If the screen is compatible, is the the 30-pin to 40-pin FPC available for purchase?  I could not find any such cable being sold separately.
Rick
userHeadPic Rick.Downs
