Forum >SEN0441 Fermion: MEMS Gas Sensor - MiCS-2714 reading 0.0PPM Hydrogen
Troubleshooting
userHead Marcin.Barsow 2024-04-29 06:06:56 907 Views3 Replies
Hello There!
I have a problem with Fermion: MEMS Gas Sensor - MiCS-2714, trying to make Hydrogen Detector System and when I use sample code from DFRobot I always have 0.0PPM (getGasPPM). I'am producing hydrogen with electrolyzer method directly to sensor so there should be atleast 1ppm of Hydrogen.
Please check my code:
Ofcourse everything is connected as it should be.
EDIT:
Im using the newer Arduino board Wifi R4.
 * @file getGasPPM.ino
 * @brief Reading Gas concentration, A concentration of one part per million (PPM).
 * @n When using IIC device, select I2C address,
 * @n the dialing switch A0, A1 (MICS_ADDRESS_0 is [0 0]), (MICS_ADDRESS_1 is [1 0])
 * @n (MICS_ADDRESS_2 is [0 1]), (MICS_ADDRESS_3 is [1 1]).
 * @n When using the Breakout version, connect the adcPin and PowerPin
 * @copyright Copyright (c) 2010 DFRobot Co.Ltd (http://www.dfrobot.com)
 * @license The MIT License (MIT)
 * @author ZhixinLiu(zhixin.liu@dfrobot.com)
 * @version V1.2
 * @date 2021-06-18
 * @url https://github.com/DFRobot/DFRobot_MICS
#include "DFRobot_MICS.h"
#define CALIBRATION_TIME   3                      // Default calibration time is three minutes
// When using I2C communication, use the following program to construct an object by DFRobot_MICS_I2C
 * select i2c device address
 * MICS_ADDRESS_0               0x75
 * MICS_ADDRESS_1               0x76
 * MICS_ADDRESS_2               0x77
 * MICS_ADDRESS_3               0x78
//#define MICS_I2C_ADDRESS MICS_ADDRESS_0
//DFRobot_MICS_I2C mics(&Wire, MICS_I2C_ADDRESS);
// When using the Breakout version, use the following program to construct an object from DFRobot_MICS_ADC
 * adcPin is A0~A5
 * powerPin is General IO
#define ADC_PIN   A0
#define POWER_PIN 10
DFRobot_MICS_ADC mics(/*adcPin*/ADC_PIN, /*powerPin*/POWER_PIN);
  Serial.begin(115200);
  while(!Serial);
  while(!mics.begin()){
    Serial.println("NO Deivces !");
    delay(1000);
  } Serial.println("Device connected successfully !");
   * Gets the power mode of the sensor
   * The sensor is in sleep mode when power is on,so it needs to wake up the sensor.
   * The data obtained in sleep mode is wrong
  uint8_t mode = mics.getPowerState();
  if(mode == SLEEP_MODE){
    mics.wakeUpMode();
    Serial.println("wake up sensor success!");
  }else{
    Serial.println("The sensor is wake up mode");
   * Do not touch the sensor probe when preheating the sensor.
   * Place the sensor in clean air.
   * The default calibration time is 3 minutes.
  while(!mics.warmUpTime(CALIBRATION_TIME)){
    Serial.println("Please wait until the warm-up time is over!");
    delay(1000);
   * Gas type:
   * MICS-4514 You can get all gas concentration
   * MICS-5524 You can get the concentration of CH4, C2H5OH, H2, NH3, CO
   * MICS-2714 You can get the concentration of NO2
   *   CO       = 0x01  (Carbon Monoxide)  (1    - 1000)PPM
   *   CH4      = 0x02  (Methane)          (1000 - 25000)PPM
   *   C2H5OH   = 0x03  (Ethanol)          (10   - 500)PPM
   *   H2       = 0x06  (Hydrogen)         (1    - 1000)PPM
   *   NH3      = 0x08  (Ammonia)          (1    - 500)PPM
   *   NO2      = 0x0A  (Nitrogen Dioxide) (0.1  - 10)PPM
  float gasdata = mics.getGasData(H2);
  Serial.print(gasdata,1);
  Serial.println(" PPM");
  delay(1000);
  //mics.sleepMode();
2024-04-29 23:12:16
Hello that's exactly code from wiki. And it still doesn't work. I was wondering if this sentence in comment has an impact:
"MICS-2714 You can get the concentration of NO2"
So I can only get NO2? with this sensor? Datasheet says opposite.
userHeadPic Marcin.Barsow
2024-04-29 22:12:32
You are using the wrong code.
The code in the following wiki should be OK:
https://wiki.dfrobot.com/Fermion_MEMS_Gas_Sensor__MiCS-2714_SKU_SEN0441#target_4
userHeadPic Yeez_B
2024-04-29 23:12:43
