Forum >SEN0482: how to read ADDRESS REGISTER after failed CHANGE ADDRESS input attempt?
userHead STEFANO60 2024-05-04 02:44:09 706 Views0 Replies
Hello!
I'm succesfully connecting Wind Speed sensor to ESP32 using simple TTL-RS485 converter, without issues.
After that, I tried to change the ADDRESS of the Wind Direction sensor SEN0482, and it stopped to answer.
I'm trying to debug the issue, and I think the easiest way would be to read the ADDRESS REGISTER (0x10 0x00) using the broadcast station number (0x00) to check the register content (because I do not know the actually stored station number) having only Wind Direction sensor connented to the RS485 bus.
Unfortunately, I cannot get any answer.
This is the inquiry frame I'm using (8 bytes):
0x00 0x03 0x10 0x00 0x00 0x01 0x81 0x1B
where:
0x00 0x03 = Broadcast station number  + read function code
0x10 0x00 = ADDRESS REGISTER
0x00 0x01 = Register lenght
0x81 0x1B = CRC-16 according to MODBUS (see https://crccalc.com/)
and I expect to read:
0x0# 0x03 0x10 0x00 0x00 0x0# CRCHigh CRCLow
where:
0x0# 0x03 = Receiving station + read function code
0x00 0x0# = stored station number
CRCHigh CRCLOw = related CRC bytes
What is wrong with this?
Is there any command to force a “factory reset”?
Here is my code,
thanks for help!
#define RS485_PIN_DIR 5  // TTL-to-RS485 command pin
#define RXD2 16
#define TXD2 17
#define RS485_WRITE     1
#define RS485_READ      0
byte leggi_frame[] = {0x00, 0x03, 0x10, 0x00, 0x00, 0x01, 0x81, 0x1B};
byte buf_addr[8];
  Serial.begin(115200);
  delay(3000);
  Serial.println("");
  Serial.println("=========================================");
  Serial.println("");
  Serial2.begin(9600, SERIAL_8N1, RXD2, TXD2);
  pinMode(RS485_PIN_DIR,OUTPUT);
  digitalWrite(RS485_PIN_DIR,RS485_READ);
  delay(1000);
  digitalWrite(RS485_PIN_DIR,RS485_WRITE);
  Serial.println("Send inquiry");
  Serial2.write(leggi_frame, 8);
  delay(10);
// Reading answer
  Serial2.readBytes(buf_addr, 8);
  delay(1000);
  Serial.println("");
  Serial.print(buf_addr[0], HEX);
  Serial.print(" ");
  Serial.print(buf_addr[1], HEX);
  Serial.print(" ");
  Serial.print(buf_addr[2], HEX);
  Serial.print(" ");
  Serial.print(buf_addr[3], HEX);
  Serial.print(" ");
  Serial.print(buf_addr[4], HEX);
  Serial.print(" ");
  Serial.print(buf_addr[5], HEX);
  Serial.print(" ");
  Serial.print(buf_addr[6], HEX);
  Serial.print(" ");
  Serial.println(buf_addr[7], HEX);
{ // do nothing
