Forum >WS2812-16 RGB LED Ring Lamp / Arduino Uno R4
General Arduino
userHead Sean.Thibeau 2024-05-11 06:34:25 375 Views0 Replies
Hi DFRobot people,
We are trying to use the WS2812-16 RGB LED Ring Lamp with the Arduino Uno R4, but the LED ring lamp software driver is not compatible with the Uno R4, the LED ring lamp driver works fine with older Uno R3 only.
Has anyone here tried the LED light ring lamp with Uno R4, wondering if the software driver may require upgrade for the newer Uno R4?
Thank you,
Sean
