Forum >SEN0487 signal problem, don't know if broken
TroubleshootingArduino
userHead Boltzmann.Krüger 2024-05-30 12:04:10 339 Views1 Replies
Hello, i made a test with the sensor SEN0487 with the program given to see the analog signal but even when i modify the sound intensity in the room, the signal given is the same, is my sensor broken ?
2024-05-31 01:47:17
Is the power supply you provide to the sensor 3.3~5V? If there is no problem with the power supply, it is likely that the sensor is faulty.
userHeadPic Yeez_B
