Forum >searching for a sample code
userHead Nidal.Shnynat 2024-06-02 04:46:03 478 Views1 Replies
I'm searching for a sample code for Arduino microcontroller that read from 4 temperature sensors (KIT0021), 1 ultrasonic distance sensor (SEN0311), 1 turbidity sensor (SEN0189), 1 Analog Current Sensor (SEN0098-V2), 1 dc voltage sensor and all that is store hourly on sd card via sd card module….
Could any one help me in that???
2024-06-03 03:11:04
You can try this sample code:
#include <OneWire.h>
#include <DallasTemperature.h>
#include <NewPing.h>
#include <SD.h>
#include <SPI.h>
// Pin definitions
#define ONE_WIRE_BUS 2        // Data wire for temperature sensors
#define TRIG_PIN 3            // Trigger pin for ultrasonic sensor
#define ECHO_PIN 4            // Echo pin for ultrasonic sensor
#define TURBIDITY_PIN A0      // Analog pin for turbidity sensor
#define CURRENT_SENSOR_PIN A1 // Analog pin for current sensor
#define VOLTAGE_SENSOR_PIN A2 // Analog pin for voltage sensor
#define SD_CS_PIN 10          // Chip select pin for SD card module
// Constants
#define MAX_DISTANCE 200 // Maximum distance for ultrasonic sensor
// Objects
OneWire oneWire(ONE_WIRE_BUS);
DallasTemperature tempSensors(&oneWire);
NewPing sonar(TRIG_PIN, ECHO_PIN, MAX_DISTANCE);
File dataFile;
 // Initialize serial communication
 Serial.begin(9600);
 // Initialize temperature sensors
 tempSensors.begin();
 // Initialize SD card
 if (!SD.begin(SD_CS_PIN)) {
   Serial.println("SD card initialization failed!");
   return;
 Serial.println("SD card initialized.");
 // Create or open the data file
 dataFile = SD.open("data.txt", FILE_WRITE);
 if (dataFile) {
   dataFile.println("Timestamp,Temp1,Temp2,Temp3,Temp4,Distance,Turbidity,Current,Voltage");
   dataFile.close();
 } else {
   Serial.println("Error opening data file!");
 // Get timestamp
 unsigned long timestamp = millis();
 // Read temperature sensors
 tempSensors.requestTemperatures();
 float temp1 = tempSensors.getTempCByIndex(0);
 float temp2 = tempSensors.getTempCByIndex(1);
 float temp3 = tempSensors.getTempCByIndex(2);
 float temp4 = tempSensors.getTempCByIndex(3);
 // Read ultrasonic sensor
 unsigned int distance = sonar.ping_cm();
 // Read turbidity sensor
 int turbidity = analogRead(TURBIDITY_PIN);
 // Read current sensor
 int current = analogRead(CURRENT_SENSOR_PIN);
 // Read voltage sensor
 int voltage = analogRead(VOLTAGE_SENSOR_PIN);
 // Log data
 logData(timestamp, temp1, temp2, temp3, temp4, distance, turbidity, current, voltage);
 // Wait for one hour (3600000 milliseconds)
 delay(3600000);
void logData(unsigned long timestamp, float temp1, float temp2, float temp3, float temp4, unsigned int distance, int turbidity, int current, int voltage) {
 // Open the file for writing
 if (dataFile) {
   // Write the data to the file
   dataFile.print(timestamp);
   dataFile.print(",");
   dataFile.print(temp1);
   dataFile.print(temp2);
   dataFile.print(temp3);
   dataFile.print(temp4);
   dataFile.print(distance);
   dataFile.print(turbidity);
   dataFile.print(current);
   dataFile.println(voltage);
   dataFile.close(); // Close the file
   Serial.println("Data logged.");
 } else {
userHeadPic lia.ifat
