Forum >DF Mini Player - How Do I Pause Play with Pushbutton?
Troubleshooting
userHead Tony.contrada 2024-06-06 08:46:57 707 Views1 Replies
I have the DFR0299 Mini player. I can select the first file to play by grounding pin 12 (ADKEY1).
According to the wiki page a 33K resistor from pin 12 to ground should Pause the playback. When I try this, it does not Pause the playback.
Am I missing something?
How can I Pause or Stop Playback from a pushbutton?
Thanks,
Tony
2024-06-06 12:49:36
OK, I found out that I just needed to provide a momentary connection via the 33K to ground. If I held the connection to ground it would not Pause the audio. I guess some clarification in the documentation might help.
userHeadPic Tony.contrada
