Forum >Error Gravity: 2-Channel I2C DAC Module (0-10V)
TroubleshootingGravity
userHead ahds.hausdf 2024-06-06 12:56:59 547 Views1 Replies
I would like to use the Gravity: 2-Channel I2C DAC Module (0-10V)(https://www.dfrobot.com/product-2613.html) to control a fan.
It is connected to an ESP32 Relay Board and should be controlled via Home Assistant using I2C.
The fan is a Systemair (https://shopng.systemair.com/upload/assets/WIRING_PRIO_EC_20201002_080052049.JPG?aa0cdd3b)
Unfortunately I always get the following error message (see screenshot)
I have tested it on 3V and on 5V.
Can anyone possibly help?
Here is a snippet of the YAML:
<div class="box">
# Output via 2-channel I2C DAC module (0-10V)
gp8403:
voltage: 10V
i2c_id: bus_a
output:
- platform: gp8403
gp8403_id: out10v
channel: 0
- platform: gp8403
gp8403_id: out10v
channel: 1
#Exhaust PWM OUT
- platform: ledc
pin: GPIO4
# Set MIN and MAX for exhaust PWM fans here!
min_power: 20%
max_power: 100%
zero_means_zero: false
</div>
2024-06-06 13:18:24
userHeadPic ahds.hausdf
