Forum >Connecting SEN0546 to Raspberry Pi
userHead Jackson.Ryan 2024-06-07 08:36:49 1277 Views4 Replies
Hi, I recently acquired a SEN0546 Temperature/RH sensor and I am trying to connect it to my raspberry pi using python, but I am struggling to write the code as this is new to me. I see that the sensor was originally designed with the Arduino in mind with the C++ sample code and such. Can someone provide advice on how I would write similar python code to get this sensor to work on my raspberry pi?
2024-10-04 14:58:41
I've got this sensor working with Python on the Raspberry Pi with the following code - hopefully that helps!
import smbus
import time
# I2C channel 1 is connected to the GPIO pins
channel = 1
#  SEN0546 defaults to address 0x40
address = 0x40
bus = smbus.SMBus(channel)
while True:
    # request temperature read
    bus.write_byte(address, 0x00)
    # wait briefly
    time.sleep(0.3)
    # read the 2 byte temperature value
    val1 = bus.read_byte(address)
    val2 = bus.read_byte(address)
    # wait briefly
    time.sleep(0.3)
    # request humidity read
    bus.write_byte(address, 0x01)
    # wait briefly
    time.sleep(0.3)
    # read the 2 byte humidity value
    val3 = bus.read_byte(address)
    val4 = bus.read_byte(address)
    # calculate the human-readable values
    tempData = val1 << 8 | val2
    humidityData = val3 << 8 | val4
    temp = (tempData * 165 / 65535.0) - 40.0
    hum =  (humidityData / 65535.0) * 100
    # print the result
    print(f'temp(C): {temp}')
    print(f'hum(%RH): {hum}')
    time.sleep(1)
userHeadPic Dylan.Black
2024-08-14 16:53:47
Did this every get a response?  I am having the same issues
userHeadPic Llewellyn.Owens
2024-06-28 10:34:49
Is this sensor support by the RPi, can someone from DFRobot confirm this?
userHeadPic Jackson.Ryan
