Forum >Gravity: I2C 4-20mA DAC Module
TroubleshootingGravity
userHead Neil-drf.Hancock-drf 2024-06-07 11:10:41 1230 Views1 Replies
I'm looking to understand the 4-20mA https://www.dfrobot.com/product-2625.html Gravity: I2C 4-20mA DAC Module
That is I'm verifying the way it works and the software drives it.
Has anybody had success using it?
On the bottom it appears to be referencing the wrong schematic and IC. DAC Dual Voltage and GP8403 IC
Stepping to the wiki https://wiki.dfrobot.com/SKU_DFR0972_I2C_4_20mA_DAC_Module
The schematic now aligns with function - https://dfimg.dfrobot.com/nobody/wiki/8b0137351912abee5b44c26e0943d10d.pdf
but the IC GP8302 is in Chinese -  is there an english translation.?
Even looking at the Chinese spec - I don't see what  I would expect to be an I2C DAC registers.?
If something needs tweaking, how to understand the registers.
The PMOSFET driver is understandable https://www.lcsc.com/datasheet/lcsc_datasheet_2203252253_GL-GL14P04-8_C2986238.pdf
 thanks if anybody has used it
